Straight axle conversion
I need to know where I can find a straight axle conversion for a 96 Z71... what all is involved, how much does it cost, and what is a good front end to use on a budget but won't let me down?
This will get you started, here is the only kit that I know of:
http://www.offroadunlimited.com/ProductCar...2&idproduct=156
$750 and you have to buy all of the following in addition:
OTHER PARTS REQUIRED TO COMPLETE THE CONVERSION:
An exhaust modification is required with this kit.
A non Autotrac transfer case is required
Crossover Steering Kit.
Front axle assembly with 32½" spring pad width.
Front leaf springs (88-91 Chevy Blazer or Suburban type).
Front & rear shocks.
Brake lines.
Front drive shaft (contact your local drive shaft specialist).
Front u-bolts.
Rear springs and/or rear block and u-bolts.
This guy is putting 14 bolt FF axles on front and rear, and replacing his tranny and transfer case, hes over $6000 and hasn't even bought wheels/tires yet.
http://www.gmfullsize.com/forum/showthread...?t=46572&page=3
