Space behind Extended Cab Seat
ZZebes
I am wanting to buy an Infinity BassLink T to go behind my rear seat in my extended cab, My question is two fold,
1) How hard is it to remove the rear seat???
2) Will a BassLink T fit???
BassLink T
BassLink T
14-3/8 x 40-3/8 x 6-7/16 are the dimensions off the website, get a measuring tape and get to measuring! :cheers:
Also, a year on your truck would help alot.
2006 and i looked and that ain't gonna be easy to get back there with all that insulation and lack of access, which leads me to my next question, How hard is it to remove that back seat??
In my '02, it was 5 (18mm) bolts, and you just lift it out. Cumbersome, but I did it by myself.
I mounted two pretty big amps and my capacitor back there with tons of room to spare.
Yeah the only thing i have to go on is me reaaching my hand up there while the seat is folded with all that insulation still there, Speaking of insulation. Did any of ya'll put dynamat or some type of rubberized coating on the back wall to replace the insulation???
I think I used...Um..."Brown Bread" deadener.
Cheaper than Dynamat, and worked great.
I really don't know if the basslink will fit back there though...It SEEMS like it should, but I've never tried it.
Not sure if the Infinity basslink would fit back there? Pretty narrow/small area!
I know it may not be quite as good as the Infinity but another suggestion would be the Clarion SRV303. It's pretty narrow and may fit up in there?
BassLink T
After having mine out doing some audio mods I'd have to say "no" it's not going to work....isn't that designed to go behind the seat of a single cab truck?
John
BassLink T
John
the biggest problem is going to be the middle seat belt bolt it does not want t come off easily the rest is just lifting sometimes you have to pry on seatbelt bolt with scredriver
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 478 Guests (See full list)
