Rock vs Transfer Case
jbunceiii
So my 01 GMC 1500 Sierra 4x4 had a encounter with a rock thru the front transfer case, the rock won. Went right thru the case. I have a question, if I buy the Z71 package skid plates for the oil pan and transfer case would that provide more protection. Will they fit? Or anyone have an aftermarket Skid plate idea? I would think that my truck did not have a skid plate.
Any ideas??
Here's the build sheet for my truck...
Vehicle Build
VIN 2GTEK19T111278785
VEHICLE BUILD
Merchandising Model : TK15753 -2001 SIERRA 1500 4WD 4 DOOR PICKUP
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : CQMJ9J
Build Date : 01/23/2001 Build Plant : 21153
OPTION CODES
AG1 - 6-WAY POWER DRIVER'S SEAT
AG2 - 6-WAY PWR DRIVER & PASS SEAT
AJ1 - DEEP TINTED GLASS
AM7 - FOLDING REAR SEAT
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
A95 - HI-BACK RECLINING BUCKET SEATS
B30 - FULL COLOR KEYED CARPET W/MATS
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR-KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
C60 - AIR CONDITIONING-FRONT
C7H - GVW RATING - 6,400 LBS
DK6 - OVERHEAD CONSOLE
D07 - FLOOR SHIFT CONSOLE
D48 - DUAL ELECT REMOTE CONT MIRRORS
EVA - EVAP EMISSION REQUIREMENT
E62 - SPORTSIDE BODY
FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ – RH
GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JC5 - 4 WHEEL POWER DISC BRAKES
KNP - TRANSMISSION COOLING SYSTEM
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
K68 - ALTERNATOR 105 AMP
LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NF2 - FEDERAL EMISSION SYSTEM
NG1 - FEDERAL/NY/MA/ME/VT EMISSIONS
NP5 - LEATHER WRAPPED STEERING WHL
NP8 - 2-SPEED ACTIVE TRANSFER CASE
OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
PY2 - CHROME PLATED STEEL WHEELS
P03 - CHROME WHEEL CENTER CAPS
QNL - P245/75R16-109S ALS WOL TIRES
SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS
T96 - FRONT FOG LAMPS
UP0 - AM/FM STEREO W/CASSETTE & CD
UQ3 - ENHANCED PERFORMANCE SPEAKERS
UY7 - HD 7-LEAD TRAIL.WIRING HARNESS
VB3 - CHROME RR STEP BUMPER
VG3 - CHROME FRT BUMPER W/ RUB STRIP
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V22 - CHROME GRILLE SURROUND
V73 - STATEMENT OF CERT. U.S.
XNL - P245/75R16-109S ALS WOL TIRES
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLT DECOR INCLUDES: -FRONT LEATHER SEATING SURFACES -POWER WINDOWS & LOCKS -REMOTE KEYLESS ENTRY -AIR CONDITIONING -CHROME GRILLE & REAR BUMPER
YNL - P245/75R16-109S ALS WOL TIRES
ZNL - P245/75R16-109S ALS WOL TIRES
ZY1 - SOLID COLOR
Z82 - HEAVY DUTY TRAILERING EQUIP.
Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE
Z88 - GMC TRUCK NAMEPLATE
1SC - MARKETING OPTION PACKAGE - 1SC SLE TRIM
1SZ - MKTG OPTION PKG DISCOUNT
12D - GRAPHITE - CUSTOM CLOTH FULL FEATURE BENCH SEAT
12I - GRAPHITE INTERIOR TRIM
50U - 50 SUMMIT WHITE-SOLID
6YH - COMPONENT FRT LH COMPUTER SEL
7YH - COMPONENT FRT RH COMPUTER SEL
Any ideas??
Vehicle Build
VEHICLE BUILD
OPTION CODES
A31 - POWER WINDOWS
SLM - STOCK ORDERS
ZY1 - SOLID COLOR
I think that those are pics of your front axel aren't they? Your t-case is between your tranny and the driveshaft, but I think the z-71 plates cover the front axel as well as the oil pans and t-case(2 seperate plates). as far as aftermarket, I don't know.
The factory skid plate package will cover and protect the front axle and oil pan up to a certain point. It is aluminum, so slamming it down repeatedly on rocks would not be a real good idea. The crossmembers to bolt it up to should be present on your truck. It has two bolts in front, right behind the plastic air dam that you can see in your picture and two bolts in back that mount through "body mounts" on the skid plate to another crossmember right behind/underneath the oil pan. Check and see if you have the crossmembers and holes there and it should work. The skid plate makes it a PITA to change the oil without making a mess though. Nice shot of the ring gear....that stinks that happened to you, that would be my luck. Good luck with it man!
My skid plate had been sitting in the shed for about 18 months up until Thursday last week... Pulled it off when I was changing a halfshaft and never put it back on. I changed the oil and reinstalled it just cause I was sick of looking at it leaning up against the wall. No rocks in SE GA to worry about it when it was off....
