Denali Projector Headlight Assembly
These things really look kewl.  I have a few questions.  Any help would be greatly appreciated.  I want to buy the oem type and not aftermarket.
Do they bolt right in?
Do u have to adjust the beam, or will it be correct?
Do they take the same bulbs as stock GMC Sierra?
What are the part #'s?
Where is the best place to purchase them?
I called a the parts dept of where is bought my truck and the guy said there is a different headlight depending if u have fog-lights.  They also said they are 253.30 each
The lights are for the truck described below.
It is a direct swap with your 1999-2002 Sierra. Should take you no longer than 10 minutes ;)
Here are the part numbers:
15166756 LH - Denali Headlamp
15166757 RH - Denali Headlamp
They are roughly $153 each from GM. To order, contact Jason Cromer at 1-877-726-8295  [email protected]
Best shipping prices around on GM parts.
Well the low and high beam projectors both use the same bulb, its the lens that takes care of the low vs high beam stuff - both use the stock high beam bulb, and if you're going to get after market bulbs make sure to get high beam bulbs without the painted tips.
I love my lights, really glad I did the switch!
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,144 Guests (See full list)
