not so newb
radill
Actually I have been a follower for some time now. First joined the site back in 2002 after my first Silverado purchase. Then again with my Avalanche. After a year in Iraq, I just got into a 2006 2WD Crew Cab with a 4.8L. It is an LS with very few ammenities. Looking forward to the mods (wife is not).
GREAT site that has grown very much...
SF
Jacksonville, NC
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
