Will this work??
hey.. i just wanna know what you guys think or if you know if it will even work?? so i own a 2005 GMC sierra with a 5.3 and im going to throw on an LS1 intake manifold, LS1 heads with Manley springs and retainers and a 6.0 cam... and have it tuned. how much (if it will even work) differents will it make.. like how much of a horsepower gain do you think that i am going to get?? thanks!!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
