pick-up trucks and cows
PELICAN
A wise old Texas Rancher went to town to trade for a pickup truck he
saw
advertised in the paper for an unbelievably low price.
After showing the salesman which truck he wanted,
they sat down to do the paperwork.
The salesman handed the rancher the keys and the bill, to which the
Texas
rancher angrily declared,
"This ain't the price I saw!"
The salesman went on to tell the wise old Texas rancher how he was
getting
extras such as power brakes, power windows, special tires etc. and
that
made the final price higher.
The Texas rancher wanted only that truck and no other, so he
begrudgingly
paid the price and drove it home.
A few months later, the salesman called the Texas rancher:
"My son is in 4-H and he needs a cow for a project.
Do you have any good cows for sale?"
"Yep, I've a few good cows priced to sell at $500 each.
Come on out and take your pick."
The salesman said he and his son would be right out.
After spending a few hours in the field checking out all the rancher's
cows,
they decided on one and the salesman proceeded to write a check for
$500.
"Now, wait a minute, that's not the final price of the cow. You're
gettin'
extras and you have to pay for those, too!"
"What extras?" asked the salesman.
"I think you'll find all you're gettin' listed here!"
BASIC COW - - $500.00
Two tone exterior - - $45.00
Extra stomach - - $75.00
Product storing equipment - - $60.00
Straw compartment - - $120.00
4 Spigots @$10 ea - - $40.00
Leather upholstery - - $125.00
Dual horns - - $45.00
Automatic fly swatter - - $38.00
Fertilizer attachment - - $185.00
GRAND TOTAL - - $1,233.00
  • 3 weeks later...
