Green Keys
I have read everything I can find on the forum on the green keys, maybe I can get some help with the green keys, will they fit the 2006 2500hd and are there anything different than the previous posts that I need to know? Green key #15592573
The chassis' on the 2006's did not change so they should fit just fine.
DEWFPO
  • 4 weeks later...
Installed green keys today, took about 1/2 hr total to install, started with 37 5/8 on each side, after the install the measurement went to 40 1/8, brought them down to 39 inches to get the truck level. the only thing is that the adjusting bolt is almost all the way out. I will keep an eye on it.
Just wanna make sure....
Green Key part #'s
15592573 Left (drivers)
15592574 Right (passenger)
Is this correct?
