Need part numbers for fuel pump
I need the GM part numbers for a 99 silverado fuel pump 5.3L
also, the part number for a E85 GM pump for the newer trucks, and are they interchangable?
I'm going to need your VIN to give you the correct part number.
As far as the interchangabilty with the E85 pump..NO.
If your truck is not E85 "Flex-Fuel" ready from the factory you cannot change it over,Theres more than just changing the pump to be able to run E85,The lines and fuel rail are different,along with the PCM programming and sensors (Which senses how much E85 your running and adjusts the programming accordingly)
If your truck is not programmed to run on E85 we cannot "reprogram" the PCM to run on it.
Now I'm not saying that you couldn't change everything over from a wrecked "donor" Flex-Fuel truck to your truck but it would be time and cost consuming,And you would need everything from the fuel system,Plus all the sensors and the PCM.
Heres a couple bulletins from GM on E85.....
Subject: Use of E85 Fuels in Vehicles Not Certified As Being FlexFuel Compatible/Aftermarket Conversion of Vehicles to Operate on E85 Fuels #06-06-04-035 - (07/13/2006)
Models: 2007 and Prior GM Passenger Cars and Trucks NOT FlexFuel (E85) Compatible (including Saturn)
2007 and Prior HUMMER H2, H3
2005-2007 Saab 9-7X
Aftermarket Conversions of Vehicles to Use E85 Fuels
General Motors has become aware of several companies that claim to be able to convert vehicles equipped with gasoline engines to be compatible with E85 Fuels.
• Vehicles certified by GM as being FlexFuel (E85) compatible contain numerous calibration and component differences that are not conducive to an aftermarket retrofit.
• General Motors DOES NOT support or endorse conversions that may alter the emissions and related emissions components of its vehicles.
• Repairs that may result from changes to GM built components, and repairs that result from the use of improper fuel, such as the use of gasoline containing more than 10% Ethanol in a non-FlexFuel certified vehicle, are not covered under the terms of the New Vehicle Warranty.
E85 Compatible Vehicles
The only E85 compatible vehicles produced by General Motors are:
• 2000-2002 S-Series pickups with 2.2L (VIN 5- RPO L43)
• 2002-2005 full-size pickups and utilities with 5.3L (VIN Z -- L59)
• 2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe with 5.3L (VIN Z -- RPO L59)
• 2006 Chevrolet Impala, Monte Carlo with 3.5L (VIN K -- RPO LZE)
• 2006 GMC Sierra, Yukon, Yukon XL with 5.3L (VIN Z -- RPO L59)
• 2007 Chevrolet Avalanche, Suburban, Tahoe with 5.3L (VINs 0, 3 -- RPOs LMG, LC9)
• 2007 GMC Yukon, Yukon XL with 5.3L (VINs 0, 3 -- RPOs LMG, LC9)
• 2007 Chevrolet Impala, Monte Carlo with 3.5L (VIN K -- RPO LZE)
• 2007 Saturn Relay, Buick Terraza, Chevrolet Uplander, Pontiac Montana SV6 (Canada Only) with 3.9L (VIN W -- RPO LGD)
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Heres the second one...
Subject: Usage of E85 Fuels in GM Vehicles #05-06-04-035B - (05/31/2006)
Models: 1997-2007 All GM Cars and Trucks
2003-2007 HUMMER H2
2006-2007 HUMMER H3
1997-2007 Isuzu NPR Commercial Medium Duty Trucks
2005-2007 Saab 9-7X
1997-2007 All Saturn Vehicles
This bulletin is being revised to add additional information on E85 fuels. Please discard Corporate Bulletin Number 05-06-04-035A (Section 06 -- Engine/Propulsion System).
Customer Interest in E85 Fuel
As the retail price of gasoline increases, some locations in the country are seeing price differentials between regular gasoline and E85 where E85 is selling for substantially less than regular grade gasoline. One result of this is that some customers have inquired if they are able to use E85 fuel in non-E85 compatible vehicles.
Important: Only vehicles designated for use with E85 should use E85 blended fuel.
E85 compatibility is designated for vehicles that are certified to run on up to 85% ethanol and 15% gasoline. All other gasoline engines are designed to run on fuel that contains no more than 10% ethanol.
Notice: Use of fuel containing greater than 10% ethanol in non-E85 designated vehicles can cause driveability issues, service engine soon indicators as well as increased fuel system corrosion.
Using E85 Fuels in Non-Compatible Vehicles
General Motors is aware of an increased number of cases where customers have fueled non-FlexFuel designated vehicles with E85. Fueling non-FlexFuel designated vehicles with E85, or with fuels where the concentration of ethanol exceeds the ASTM specification of 10%, will result in one or more of the following conditions:
• Lean Drivability concerns such as hesitations, sags and / or possible stalling.
• SES lights due to OBD codes.
• Fuel Trim codes P0171 and / or P0174.
• Misfire codes (P0300).
• Various O2 sensor codes.
• Disabled traction control or Stability System disabled messages.
• Harsh / Firm transmission shifts.
• Fuel system and / or engine mechanical component degradation.
If the dealer suspects that a non-FlexFuel designated vehicle brought in for service has been fueled with E85, the fuel in the vehicle's tank should be checked for alcohol content with tool J-44175. If the alcohol content exceeds 10% , the fuel should be drained and the vehicle refilled with gasoline - preferably one of the Top Tier brands.
Repairs to non-FlexFuel vehicles that have been fueled with E85 are not covered under the terms of the New Vehicle Warranty.
A complete list of GM’s FlexFuel vehicles can be found in this Service Bulletin, or at www.livegreengoyellow.com.
Notice:
• Only vehicles that are listed in the E85 Compatible Vehicles section of this bulletin and/or www.livegreengoyellow.com are E85 compatible.
• All other gasoline and diesel engines are NOT E85 compatible.
• Use of fuel containing greater than 10% ethanol in non-E85 designated vehicles can cause driveability issues, service engine soon indicators as well as increased fuel system corrosion.
• Repairs to non-FlexFuel vehicles that have been fueled with E85 are not covered under the terms of the New Vehicle Warranty.
  • 1 year later...
[quote name=
Hi,
I'm installing a 2006 L59 "z" vin silverado engine into my 1969 Firebird. I am also looking for the fuel pump part number. The 2006 didn't use a flex fuel sensor, did it?
:thumbs: After a certain level of mods, sure!! Match it with some 8.1l injectors and hit the road!!! If I went anything over 100 dry shot of nitrous, I'd look into larger injectors, and this pump!! I'd hate to run out of fuel @ 5500+RPM while spraying.....:cheers: Or just go with a wet kit and not rely on the MAF or injectors.
    250.3k
    Ragg-Boy
    Ragg-Boy
  • Who's Online   6 Members, 0 Anonymous, 965 Guests (See full list)
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
