OU vs. Oregon
Dyabolical
I am waiting for a link on it, but the "review officials" for the PAC-10 have already been contacted by the NCAA to launch and investigation over the last 2 completely obvious bad calls.
The pooch kick was touched by the kicking team just 8 yards before OU had a chance to recieve it.
The pass interference call went from a perfect spiral to an out of control tumbling ball in the air.
Courtesy of a buddy of mine that is a staff writer for the AP.
Comments?
It's a good thing I'm a level-headed kind of guy, or I'd be needing a new DLP right now.
I'm not sure which is worse...Those calls, or the couple made by the zebras at the Colts/Steelers game last year.
My comments would start fires in my living room...So I'll keep quiet.
Also have you seen the new footage showing that on that onside kick, the Ducks didn't even get the ball. You can see it come out from underneath an OU players legs, and another OU guy picks it up.
I saw that during the f'n game.
Comments?
Yea....insane. Pac 10 officials blatantly gave the game to Oregon.
So...there gonna investigate it? What does this mean. If the NCAA determines the calls were bad would OU be awarded the victory?
I always hear this. "there gonna investigate it" How long does it take, and what becomes of it?
least my Cougars were pretty dominant....
PS - Even CollegeFootballNews is mad about it. http://cfn.scout.com/2/569266.html
Hey guys, been without the net for a few days. :cool:
I laughed out loud when the news busted. I had been telling the guys at work all day before it went public and they didn't believe me. That'll show them...
Anyway, the NCAA supposedly doesn't have any provisions for deleting a game...so we will have to see.
Also, i have relatives that live in Oregon....i guess they aren't talking about it too much up there, but what is being said is that OU should just suck it up and accept the loss and stop being sore losers and whiny babies.....
.......REALLY puts me in the mood for busting out the 12 guage mag for duck season.
Anyway, back to no tv or telephone or internet. :banghead::banghead::banghead:
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
