1991 S10
ZZebes
A friend of mine is trying to sell his 1991 S-10 pickup, it isn't in the greatest condition. It has lots of surface rust, in fact the paint matches the rust, or the other way around. The truck runs pretty well considering the odometer broke around 300K i will post pics tommorow, the truck looks like a POS on the outside but the frame is pristine and never wrecked, I wanted to buy it as a project truck like the S10K from spike, but alas i cant.
So down to the nitty gritty, He is asking $500 for it. Shipping/delivery is up to the buyer. If it is within a decent area of Houston, TX i will deliver it for the cost of the gas and the trailer rental.
BTW, If you hadn't already guessed, it is located in Houston, TX
PM me with any intrest, All offers will be considered
