Bulb question
GatorFan
One of the bulbs is out in my 2000 Sierra A/C cluster and I needed to know the bulb type/part # so I can replace it. I know you have to unsolder the old bulb and resolder the new one back on the circuit board, but I don't want to get the wrong wattage bulb before I begin.
Thanks.
