Budget sound system
cyoung1253
Ordered the rest of my "budget sound system" today.
Kenwood DPX-501 head unit
http://www.kenwoodusa.com/products/ListPro...&k3=173&pr=2377
Kenwood Excelon KFC-X170 front doors
http://www.kenwoodusa.com/products/ListPro...&k3=159&pr=2151
Kenwood Excelon KFC-x460 rear doors
http://www.kenwoodusa.com/products/ListPro...&k3=165&pr=2157
Also got a Rockford Fosgate P110S4 sub to be installed into my home-built sealed enclosure under the rear seat.
http://www.rockfordfosgate.com/products/pr...89&locale=en_US
It will be powered by a Pioneer GM-3200T bridged to deliver 150w @ 4 ohms
http://www.pioneerelectronics.com/pna/v3/p...91522415,00.htm
Total outlay so far is $490 including an 8 guage amp wiring kit, the enclosure was built out of materials I had kicking around so no cash spent there. Just under my $500 target :nopity:
I'll be running the coaxials off the head unit at 22w rms x4 for now, should I install "bass blockers" on them and let the sub do the hard work or just run 'em full range? I'm thinking >100hz on the 6 3/4's and >300hz on the 4x6's. Opinions/advice appreciated.
Truck is '05 Sierra ext cab WT with the crappy 4 spkr AM/FM radio that has just got to go.
You shouldn't need any bass blockers...The pre-amp outs will go to your amplifier, where you should be able to set the freq for it's high end...Just overlap that a bit with what the frequency response range for the coaxials/stereo combo, and you should be gold.
That's going to sound bada$$...ESPECIALLY for spending under $500. :nopity:
I'm not too worried about the front door speakers, they should be able to take whatever the 22wx4 channel head unit can dish out. Just wondering most if I should cut back on the low frequency abuse to the 4x6 rears.
Well...I've installed them before, and they do work.
I think I paid about $4 each for them. And they just install inline into the + speaker wire.
Update
Finally got aroung to installing the "budget system". Used some 1/8" foam padding left over from a flooring project to insulate and seal the door panels to cut down on road noise.
Extra 1/2" thick foam rubber was added to the plastic panels around the speakers front and rear.
Comparison of OEM speakers and the Kenwood KFC-X170's. No wonder it sounded so crappy.
Had to fab a couple of brackets to install the double-DIN sized DPX-501.
Fits perfect in the factory cut-out. Unit is a hair crooked in this pic, tweaked the brackets to straighten it.
Here is the home-built sub-box. Used bed liner spray to finish it and it looks right at home in the Work-Truck interior. The Pionner amp is small enough to hide behind the sub-enclosure and held in place with heavy duty velcro strips.
How does it all sound? :rolleyes::thumbs::thumbs::thumbs::thumbs:
Bass from the down-firing sub has plenty of thump. No bass blockers needed for the door speakers as the Kenwood deck features high-pass filter adjustments for front and rear as well as low-pass sub pre-out adjustments. The DPX-501 has tons of tweaks and settings to choose from and is a bit confusing at first. (I actually had to read the frickin manual :eek: )
Will it win any "crank-it-up" contests and make your ears bleed? Of couse not but it plays well above comfortable listening level and makes the rear-view mirror vibrate. Huge improvement over the P.O.S. radio GM put in, and worth every penny of the $500 I spent. :cheers:
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
