New Diesel Owner! LB7 Dmax
As I mentioned in my other topic, I was looking at trading the 8.1L for a Dmax. I went ahead and bought it. Super truck! Fellow diesel owners, can you give me any hints or advice? I've never owned a diesel and not sure about a few things. What type of fuel to burn, etc. Is bio-diesel okay to run? What about winter? What I know for sure is to wait for the intake heater light on the dash to go out before starting engine. Is this correct? I can't wait to pull something! He, he!
Definatly wait for the glow-plug light to go out before you crank it over.
If you want to run bio-diesel, then you will end up having to change your fuel filter several times. I've heard that when you switch from diesel to bio-diesel, that all the crud that accumulated in your tank and fuel lines will eventually get cleaned out and will end up in your fuel filter.
If you stick to running regular diesel fuel, then you will need to change the fuel filter every other oil change (at least that is the way the computer in my truck is making it work out).
You have alot of extra untapped HP under the hood. I put the Edge EZ chip on mine and what a difference it makes. I know it's not the Edge Juice/Attitude that everyone craves, but i didn't want to change the stock exhaust (which is a necessity with that system).
Enjoy your truck and that grin will get even bigger when you hook up to your 5'er! :nopity:
Thanks for the tips. :nopity: As far as the Bio-diesel goes, it isn't any cheaper than regular fuel, so I'll stick with that for now. When I filled the tank this morning, there were 3 pumps on the island I was at. #2 diesel, Premium diesel, and bio-diesel. What is the premium diesel?
Premium diesel is probably just a marketing ploy with some unneeded additives. Most pumps I see have a maximum of 3 options: #2, #1 and dyed (tax-free, off-road, etc). Stick with the #2 all year round, it's blended with #1 in winter if you live in a climate that requires it. No need to blend yourself.
The Edge /w Attitude does not require a different exhaust... it's the same module with an extra power option added with the Attitude. The higher performance levels require numerous changes to reach their full potential.
I've heard from numerous people the LLY makes 26mpg highway with the edge at the economy level and a good aftermarket exhaust.
When you change your oil, watch for the skid plate, if you do not install a quick drain. The skid plate sticks out far enough to interupt the drain flow and catchs the oil and makes a big mess if your not careful. I always fashioned a barrier out of cardboard that did the trick.
Also, if you've got a good load behind you and your running your cruise in hilly terrain, then the mph will swing upwards of 10mph between the trough and crest of the cycle. At least it did with my 03.
Enjoy your truck.
Hope I make more friends than yesterday!!! Man
Enjoy the Fumes!!!
Check out www.dieselplace.com. Great site for GM Diesels. Also we need pics to be able to believe you :)
Will
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
