Can you hear your AC compressor engage?
My 06 makes an audible sound, and slightly hesitates when the engine is under a heavy load.
Luckily, there's only a few months out of the year that you would even want the AC on here.
Barely audible on mine, certainly a lot more quiet than my 95 Nissan pickup A/C clutch was. But oddly enough it worked flawlessly for 10 years without me ever touching anything.
The noise you hear when tthe A/C compressor kicks in is just the clanging noise of the compressor clutch metal disc being pulled in. Sometimes, it is also a noisy A/C relay. the noise you should worry about is steady metallic grinding noise when the compressor is running. You typically hear it when you buy a "rebuilt" A/C compressor from Auto Zone and install it and run the A/C for about a month. Avoid cheap rebuilt A/C compressors like the plague! New A/C Delco compressors are not that expensive and will give you years of service.
i can barely hear mine kick on and still cold been six years and still havent charged it but i do get a ticking noise when its on sounds just like the lifter tap if anyone has an idea about that id love to hear seems to be coming from the drivers side i dont have any clue
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
