Emergency Brake Cable
BAD2500HD
Sorry this isn't about my truck but i need some help and hoping somebody could help me , my daughter has a 1998 Malibu and the emergency brake doesn't hold at all , i need to get this car inspected for her and this is the only thing wrong with it ( we just bought this for her , it's her first car ) is there anyway to "take" the cable up ? and if there is how do i do it ? Thanks again for your help !
It's probably not the cable but rather the e-brake assembly itself at the rear wheels. On that car I'm not sure if you have drums or rotors. If you have drums you probably need to adjust them (maybe time for a rear brake job?) and it SHOULD fix the problem. If you have rotors, I'm not sure if they're set up like my fiancee`'s Jimmy with an e-brake drum inside the rotor or if it's part of the caliper assembly...You'd have to do some investigation to find out.
Yes this car has drums on it , but after i went out thurs. afternoon to look at it i found that the cables had pulled apart at the piece that hooks both together the other day it was like that so it must have happen when i went back out a tried it again anyhow not sure if i will have to get new cable or not but will ttry this weekend and see what i can do , the drums and shoes look very good now for my truck it has the drums inside the rotor now is there a way to take them up just like a reg. brake ? i just put new rotors and pads on it but not the e-brake shoes never gave it a thought . thanks for the help !
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
