help! need to pass inspection! no tail lights!
nuttinweez69
:smash: help! i need a wiring diagram for my 1996 chevy tahoe 4wd. i have no tail lights, but brake and back up lights work. tried the fuses, bulbs. is there something we're missing?
I don't have a wiring diagram since our service information only goes back to 1998, but let me ask a few questions.
Do the dash lights (backlighting) work? These are fed off the taillamp circuit and if the dash lights don't work, it may be a headlamp switch. Also, how 'bout the front parking lights?
If both of the above work okay, then, I'd go back to the taillamp circuit board (sockets) and see if you're getting power for taillights. Pretty sure it's the brown wire. LOTS of problems with those circuit boards.
Do you have an added on trailer harness? We see our fair share of problems there with crappy wiring jobs.
:smash:
update........ we just found the problem.. it was a corroded trailer harness..thank you soo much....
  • 2 months later...
Im having the same problem that you were.. My tail Lights are out and so are my Dashlights.My Brake lights and Signal lights are VERY dim but they work , if you call that working . Fuses seem to be good. Now that i think of it there is a sketchy looking trailer hookup on the truck almost looks to be homemade or somthing. Any help would be great. thanks
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
