Power windo motor replacement
Beamer
I have a 99 Tahoe, and the passenger rear windo goes down quick and wonderful. But going up, it is getting hung up. I looked over the way the track is, and see the window shift and thought that was a problem, but the drivers does the same. If I pus downward on the rear of the window to keep it level going up, it does fine until I let go, but stops then. I am thinking that the motor is weak and needs replacing. I was inside the door today and it was lithium greased nicely, but sprayed some liquid wrench on it to see if that helped and it did not.
Now I am left to look at the motor to be bad. But how do you remove it? It does not look accessible to the mounting.
Thanks for your help and any tips on what else may be the problem.
Mike
I am not sure how different the 99 Tahoe and a 2000 Yukon are as far as going from OBS to NBS, my passenger rear window went out and it is cable operated. There is a spool that the cable wraps around on mine and my cables got all messed up. I had to buy a whole new regulator and motor as there is no regulator only option from GM. I was lucky and found a brand new regulator and motor on ebay for 25 bucks + shipping. My regulator came out with 3 bolts holding the regulator and the two clamps holding the glass (make sure you anchor that well!!). It took me less than 1/2 hour to replace it. I would do a search on your year of regulator and see what it looks like. It could be your motor or it could be the cables messing up or...if yours is like a scissor type regulator, a bushing or something going bad. My hardest hurdle was removing the door panel without breaking the tabs that goes into the door and keep from getting the black goo all over me. If it is the cable type, it will come out and go in smoothly. My motor was fine and have an extra motor now in case one of my motors goes out. Just need to keep the kids from hanging on to the window when they roll it up!
Good luck. If I can find out anything I'll post some more.
I believe it must be different, as I do not see a cable system in there. It is scissor regulator and looks like I need to drill the rivots out to remove the regulator assembly and then go from there. I did see on Ebay a regulator and motor assembly.
It is just sort of strange that the windows angles so much as it is going up, and that was my origonal thought of what was wrong, but it does the same on the driver side rear window.
Thanks for your help. I am thinking that the 1999/2000 year was the crossover for the newer model equipment as well.
Mike
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
