2wd Hub upgrade
This is from another forum, but thought you guys may be interested in it. Blitzkrieg 2wd replacement Hub Upgrade.
Here are the specs:
The hub kit will replace the weak unit bearing system with a more conventional tapered roller bearing assembly. These hubs are built in house and will retail for $950 complete and ready to install. Features will include the following.....
-Heat Treated 4130 Snout based on a Dana 44 4wd snout
-Wheel mounting surface is located between two 1.625 ID Timken bearings.
-Utilizes the stock rotor and caliper(Wheel mount surface is exactly in the same location as stock)
-No wheel modifications necessary-most aftermarket center caps will fit as well.
-Works with stock and all aftermarket cast and fabricated spindles.
Pics.......
The website has more infoBlitzkrieg Motorsports
  • 3 months later...
Hello New here I was just searching for 2wd hub and this came across.
Do you think this kit will fit on my obs tahoe (96) I have 4wd but I'm trying to make it to 2wd. this seems to be a good solution for it. if this fits it's actually really something I have to look into purchase.
I'm trying to put the air suspension on tahoe that's why this might be good solution. and lot of people can make use out of it not only 2wd people.
  • 1 month later...
if your spindle has the 3 bolt flange on the snout block, you will be able to bolt it up. They made a 5 x 5.5" lug pattern one. Heard it works on fords and dodges new spindles?!?!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
