suspension lift
i have a 97 K1500 and was looking at rough country's web site. saw they have a 2-3 inch suspension lift. Anybody have one of these? If so how do you like it? How was it to install? any problems?
Thanks
:chevy:
I just installed the Skyjacker lift on my '95. I ordered it from Summit Racing. I also looked @ the Rough Country web site to compare the Installation. They are almost exactly the same, except new torsion bars, brake lines and shocks are included w/the kit. The Rough Country kit also comes w/better instructions and illustrations.
The installation is pretty straight forward, but if you have limited expereince it will take you awhile for the install. I would suggest installing NEW ball joints at the same time you install or have the kit installed. The only real issues I ran into was while re-installing the differential carrier, the lower bracket would not line up, I had to use my ball-joint press to move the lower carrier mount/bushing over about a 1/4" so that it would line up correctly. As far as the rear add-a-leafs, I did not use them 'cause I had replaced my rear springs a little over a year ago so that I could haul heavier loads so I already had enuff lift back there. I installed the front kit to correct the steering and axle geometry after I cranked the torsion bars. I also had to purchase new shocks and brake lines. The Skyjacker kit uses the factory torsion bars. After I purchased the new Rancho shocks and Pro-Comp stainless steel brake lines I landed up spending more than the Rough Country price for the whole kit.
My truck has over 186,000 mi. on it, so I basically re-built the whole front end @ the same time, new ball joints, tie rods, u-joints, stabilizer bar and axle shafts( the CV boots were torn on mine) It was just easier to do it at the same time while it was apart. The only parts I did not replace were the wheel/hub bearings. I will be doing that this weekend. One of them started growling this past week, probably due to the added stress of driving it w/the alignment out of whack and the age of the truck. I would suggest that you inspect every component related to the front end and plan accordingly. Also plan on a front end alignment as soon as possible after the installation is complete.
Hope this helps.
well its still advertised but who knows...if theres no interest then ill keep it. Doesnt matter to me if it sells or not. Just sits around alot.
But anyway, thanks for the compliment!
    KJEK
    KJEK
  • Who's Online   5 Members, 0 Anonymous, 654 Guests (See full list)
