Data Link Connector
amps2spare
I recently purchase an obd2 code reader. It worked great on my car but wouldn't on my truck. Upon further investigation, I have found I have no voltage on pin 16 at the DLC.I checked my fuses under the hood and in the cab, all are good.I have also discovered my cigarrette lighter dosent work but my acc. ports do! Am I missing something or do I need to chase it down in the harness?TIA :crackup:
I would recheck the cigar fuse15 amp at the underhood fuse block.
If the fuse is ok check for power to the fuse may have a problem with fuse block.
Cirgar fuse powers pin 16 at the DLC
