2nd Gear Launch
I have searched and found some info, but I need to confirm this issue. I have the option of launching in 2nd gear by placing the gear selector in D2.
Is this suppose to be there?? :crackup:
The second gear launch is there to help you control torque in low traction situation like starting on ice. Keeps you from just spinning the tires to easily. It's most useful for people with only 2wd.
I could've used this info this morning. It was very humid and the roads were very slick. My stock 245 width tires suck too.
Came in handy for the work truck I was in today (2000 Silverado 4.3L without posi or 4X4) with the snows we had here in Colorado :cheers:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
