Chevy VS Ford
Ognob350
Im not looking to drag my truck, but i was wondering what modifacations could i do inorder to beat say a Ford F150 lighting. Im speculating on the model of the ford. Right now i have a 1997 1500 with a 5.7L 350. For modifacations i have a magnaflow exhaust and a k&n air filter. Any suggestions would be great because you guys of all people know that its always important to BEAT a Ford :cheers: .
Thanks
200hp shot, and make it count. Your heads may end up on the road behind you. Those lightnings are fast.
They're not THAT fast.
A 200 shot on a stock block will grenade in no time. I'd say turbo or supercharger, and you'll be in the ballpark of a Lightning.
What year lightning??? They have a 1st gen and 2nd gen. The 2nd gen Lightnings model year 99-2001 ran high 13's on street tires. The 2nd gen Lightnings model year 2002+ ran mid 13's on street tires. Now both ET's are ideal conditions and good drivers. But you will need at least 400 crank HP to compete with a stock Lightning.
Also a $2000 investment into a Lightning will net high 12 second ET's, if not faster.
Whats funny to me is Ford had to supercharge a 5.4l for it to put out 380hp. A tune and a few bolt ons on a fake hemi would put those numbers out. Didnt want to use the 6.0 as an example because displacement.
Alot of times, that 380 hp is underrated. Just look at the 03-04 Cobra's. Stock Cobra's were dynoing anywhere from 360 to 380 hp at the rear wheels, and the engine is rated at 390 flywheel hp. If you add 18% for drivetrain losses, you get in the neighborhood of 425 to 450 hp at the flywheel.
Same principal for the LIghtnings. I used a hp calculator and estimated the HP for a stock lightning at the wheels. Most run 13.9's to 13.7's in the 1/4 mile stock. OK, take a curb weight of approx 4600 and 13.9 seconds, the calculator is saying approx 338 hp at the wheels. With a estimated 22% drivetrain lose, that would put flywheel HP at around 410 hp.
Here is a link to the calculator I used.
http://bbs.hardcore50.com/calc/index.php?mode=estimatehp
quickest way would be forced induction. An STS, Radix, or whipple/Kenne Bell would put you right there. Not to mention a good tune to couple with either of those options. You could do it N/A with a little more work (i.e tearing into the motor). Lightenings are no joke, they will leave you quick. Line up a second Gen lighteneing with an SSS (14.7), Hemi (15.3), Titan (15.4), or even a QC SRT10 (14.1) and the lightening (13.5) will win just about everyt time with a decent driver. Those times are consistant with what I have seen those trucks run stock at the track.
Well that makes sence, I always wondered how 380hp made a pickup truck run 13's. I always figured they were light trucks, guess they are kinda light. My best friend used to have a 99 f150 2wd regcab stepside with a 4.6l, it was a pretty small truck, I figured they didnt weigh much.
Well i believe the SSS and Hemi numbers but remember the Lightning is a Regular cab and all of the trucks you just mentioned are Extended or Quad Cabs. Because i know a Regular cab SRT-10 Ram would eat a Lightning for lunch.
Correct me if i am wrong but i think that a Stout 5.3L with a Whipple or a Turbo and a good dyno tune should stand up against a Lightning
Right, a standard cab srt10 will beat an L, but not for lunch i dont think. Those v10's encure some serious heat soak. Either way, i think with some forced induction and a good tune, you will be right there. Good luck.
Thanks for the advice, Ill look into forced induction. For right now, its looking like i won't have the $ to drop into my engine needed to keep up with one of those things. I appreciate all the help though.
