Radiator Hose Connectors
z85
Posted this in engine tech but maybe better here.
Time to replace the water pump on my 03 2500hd with 8.1 4x4
When I looked at the lower radiator hose I saw these new type of "clamps?' holding them on. I haven't seen this type before. How do you disconnect them? Is there a special tool? There seems to be a collar that maybe you slide back to remove? I'm old school I guess, why not regular hose clamps?
Come on guys bring me up to date.....
Any tips on water pump replacement or what brand to buy?
Z85
Well guys, since no techs want to answer this, let me tell you what I found out.
For starters I'm not replaceing this lower hose as I normally would when changing a pump. This little beauty is a dealer only item that will set you back $121.00 plus tax. Thats right, for a lower radiator hose! I checked the aftermarket and not even Gates makes this one.
Where the "hose" part of this assembly attaches to this assembly is what I was looking at and no it doesn't come apart here. You have to get the whole assembly which has the lower hose and 2 heater hoses attached to it. The assembly has a clip with "o" rings of some sort where it attaches to the radiator.
As for the pump, GM wants $234.00 for it and you can get a new aftermarket TRW for $115.00. Guess which one I'm getting.........
It's no wonder GM is going bankrupt......
