Factory Fog Lights
$100 on ebay. It is not too difficult. Just be careful when you cut the holes for the lights in the lower valence. The only part that I did'nt like was having to mess around inside of the fuse block, but it really did turn out to be pretty easy.
You don't have to have the dealer do anything to your computer. Once the lights are installed you just hit the on button and you are good to go.
Is it possible to add factory fog lights?
What all is required?
Just make sure they are powerful enough for your liking. I've read several postings, where people complained about the paltry power-rating. On our Sub, we have factory fog lights. They look nice in the apron of the bumper but not very powerful, which actually came in handy when we were pulling into campgrounds at ten-eleven o'clock at night this summer. We just turned the headlights off and kept the position markers and the foglights on. This way there was just enough illumination so that we saw where were going but did not light up other peoples' tents and camp sites.
If you want more power, you migt consider a set of aftermarket fog lights that would fit.
