Torque Underdrive
Magnumb
Hello,
I am installing March underdrive pulleys on my 1995 GMC Yukon 5.7. I am not able to find out any info on torque specs for the alternator pulley and the crank pulleys bolts. Will someone direct me on where to get this info I have Haynes reapir manual but does not have this info inside.
Thank you
