Amp kit ???
So I just bought some old school MTX black gold series (two 10" ) and this amp:
http://www.drdetailshop.com/vd2500.1.htm
the subs probably want around 500 watts each, the amp is way more powerful than i need so i wont EVER have the gain even close to all the way up, so with that in mind, what size amp kit should i buy? also, will i need to run a spare battery? a capacitor? upgrade my alternator? if my lights arent flicking (its not installed yet, so this is an IF), does that mean everything is ok?
Your best bet would be to talk to a car audio store. However, if I did this, I would run 4 or 0 gauge wire with about a 150-200 amp fuse (at least). Also a capacitor. I would not get a spare battery, just a better alternator.
www.stingerelectronics.com are top of the line products and will have everything you need.
-Hope this helps, Andrew
so the stock 145 amp alternator wont handle this?
I don't know about the alternator, sorry :) I know alittle about electronics, enough to point people in the right direction....
From past experience, I have ran 1000+ watt amps off of factory alternators with a capacitor with no problems. And have friends doing the same thing with out a capacitor.
I think you might have some overkill with that amp :D
Just throw a second battery in it, optima yellow top. :cool:, as far as capacitor, the general rule is 1 Fraud for every 500W, however by following this rule I've always had dimming headlights when putting a heavy load on my alternator (headlights, brakelights, foglights, turnsignal), so the rule I use is 1 fraud for every 300W plus 1. seems to work well. Here's a math problem for every 1000W of amp
According to law of Electricity Amps X Voltage = Watts
Amps X 14.4 = 1000W
Amps = 1000/14.4
Amps = 69.4
Therefore, for every instant that your Amp is pushing out 1000W you're putting almost a 70 Amp load on your alternator, just for your stereo, a second battery and the correct capacitors will lessen the load trememdously on your alternator.
Amps X 14.4 = 1000W
Amps = 1000/14.4
Amps = 69.4
Sorry... left this part out... if you're going to run capacitors, I'd run a 0 gauge back to your system... and then with distribution blocks run 4 gauge to your capacitors and amp, also, to your speakers, get 12 gauge speaker wire... I went from 16 gauge to 12 gauge and noticed a difference, the more power you push, the more difference you'll notice by doing this.
    juggernautusa
    juggernautusa
  • Who's Online   4 Members, 0 Anonymous, 1,194 Guests (See full list)
