GM Nav HU questions
xanth
Hi Everyone, Working on putting a TNR in my 05 SDCC.
Have what I thought to be a verified Lux Nav, Part number 15230099.
However, when I put it in my Denali, it works, but no sound.
Theftlock is still activated, I can bypass once, that is where I figure out I get no sound.
Quetions are:
How do I verify this sytem is a Lux? EQ settings are EQ 1-4 & Custom, does this in itself mean non-lux?
If I take it to a gm dealer, and have the theftlock removed, will it "repogram" the unit to the Denali, IE eq settings will be spacious, driver ect?
Is there any place that repairs/reprograms these units? I don't want to have to hunt for another one if i can help it.
Thanks for the help!
You need to have the nav programmed with a Tech2. What you describe is normal, lights up with no sound, until programming is complete. Your dealer will douwnload the info from your Denali to a Tech2, then connect the Tech2 to GMonline PC. There he will change settings(letting the truck know what radio is installed), then reload the new info to the truck via Tech2. The whole thing should take about 30 minutes...
is there a list of GM techs on here somewhere that know things like this? it would be nice to be able to have a local contact for things like this.
Re: GM Document #1275527
Radio Setup With RPO UM8
Radio Theftlock Clear Procedure
Complete the following procedure, using a scan tool, in order to properly set up communication:
Using a connected Tech2,
1. At the Main Menu screen, select: Diagnostics.
2. At the Vehicle Identification screen, select the following options:
? Model Year
? LD Trk, MPV, Incomplete
3. At the System Selection Menu screen, select: Body
4. At the Vehicle Identification screen, select the following:
? Appropriate model
? Appropriate Air Conditioning
? Navigation Radio
5. At the Body Screen, select: Navigation Radio.
6. At the Radio screen, select: Special Functions.
7. At the Special Functions screen, select: VIN Relearn.
8. At the VIN Relearn screen, the scan tool will display "Do you want to clear radio theft information?"
9. To begin clearing, press the soft touch key on the top right of the scan tool. The scan tool will display "Clearing Radio Theft in Progress."
10. Press EXIT on the scan tool and cycle the ignition.
Important:
The radio theft will learn the VIN. Without learning the VIN, the radio will display a locked message (LOC or LOCKED).
Well, got it programed and still didn't work. It must be mis-labled from GM (who knows!). Still shows the eq settings from a non-lux system, so guess I'll have to sell it and keep looking.
Thanks for the responses!
I believe the AMP designates whether it is a LUX system...not the HU - the HU just follows it. And the LUX amp is wired COMPLETELY different than the std BOSE amp. SO, if you have a LUX style HU and the std bose amp...you prolly won't get any sound.
But never fear...you can fix all this.
1) confirm which amp you have - check all the RPO CODES to see what you have - or get a physical look at your amp. The Lux amp looks considerably different than the std amp.
2) match the system - you can do one of 2 things. get the right amp.. or have your HU programmed to match the amp you have. There is a helpfull guy in Michigan that can do all the reprogramming for you. The guy goes by [email protected] .
I don't know if machomachodan has been referenced on this board...but many of the AVALANCHE people use him.
Avalanche Fan Club
Do a search for his name there.
Find out what your truck really has in it and you should be on the way to sound.
dave
Yeah, what Dave said. I don't know what the guy in Michigan charges, though.
If you want to find out for sure if your headunit is lux or non-lux, do a search on here for the pn.
I'd be really surprised if a dealer could/would reprogram a non-lux hu to a lux one.
Also, if your hu is non-lux, you can't just swap to a non-lux amp. You'd also have to do some rewiring of the amp harness. You don't want to do that anyways, because you'd lose the lux sound quality.
Hi,
I have installed and INR nav and lux bose amp in my 04 Sierra ext cab. I am in Canada, and went through the process above. The dealer tells me GM won't let them 'turn on' that function for my truck because it isn't supposed to have that radio. It works when I bypass the theftlock but the Tech 2 doesn't communicate with the radio to unlock it.
Anybody venture what would happen if I put an unlocked radio in there. Would it marry to the VIN and work? Any other ideas on how to unlock this one in the truck? Maybe a trip to a US dealer? Seems you guys don't run into the same problems down there.
Any help would be appreciated. Thanks!
I would expect so, but I'm unsure why the dealer wasn't able to unlock it with the procedure outlined above...
Went to 3 different dealers today. The one that let me observe got as far as selecting the Navigation radio on the tech 2 and it said 'digital radio not communicating'. Anybody had this happen? The radio works fine using the Theftlock bypass with the key in the ACC position.
The one thing I am not clear on from all the reading I am doing. Do you just do the unlock procedure with the tech 2 or does info need to be dnloaded to the tech 2, then get some info from GM(online) and then upload that info back into the vehicle to let the truck know the nav radio is there? I am seeing both answers in the reading I am doing, can someone clarify this?
Thanks
I personally watched a dealer service manager clear the theftlock on my INR that I bought from eBay. He never hooked up the Tech II to the GM online thingy. He just plugged the handheld into my truck, and then he punched the couple of buttons to go through the unlock procedure, and then it was done. And it's not like he did some downloading behind the scenes beforehand. When he plugged the handheld up to my truck, he'd been given no prior info about my truck. I KNOW he didn't download anything from GM.
That's why I'm still confused about your problem. I wish I could help more. I know what it's like to be in a situation like yours and feel helpless. I hope someone with more know-how than me can shed some more light on this...
--Jon
This is what limited info I have on the subject:
The tech II asks for the model of the truck during the process of clearing the VIN. If your truck is not listed...you SUBSTITUTE another model that is there.
And NO, they did not request any info from GM online when they reset mine. They just hooked up the Tech II and did everything at the truck.
Also..if the vin is already cleared...the HU should learn anew one when it powers up the first time.
dave
Hey Jon and Dave,
Thanks for giving me a clear idea of what should be done. Thanks for your help and comments. I am leaving on Friday for a few weeks with family down south. I will deal with all this again after the New Year, and post my results.
Season's greetings to all!
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 299 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
