I need to replace my stock fog lights on my 2000 Yukon (late model) are there any recommendations out there? The lenses came off mine and they suck anyway :rolleyes: so I'd just like to replace the whole light, not just the bulb.
Thanks all!
  • 3 weeks later...
I need to replace my stock fog lights on my 2000 Yukon (late model) are there any recommendations out there? The lenses came off mine and they suck anyway :) so I'd just like to replace the whole light, not just the bulb.
Thanks all!
I think the lights on your truck are the same as a pickup...have a look at PIAA 1500 series...you can get amber or clear and fog or driving...factory lamps are lame, fall either off or apart, as mine did.
Thanks all!
hey after sending that reply I'm no longer a "newbie"....feels just like when I lost my virginity!!!.........sweeeeeeeet!
Maybe I should look before I reply. The '03 fog lights are round
Do you know what size that the fog lights are for the '03 Denali? It appears that the PIAA 5164 might be a great fit, but I'm not certain.
TIA.
TIA.
Time to get out the tape measure!.....why not consider a HID bulb setup, which is what I will be adding.....go big or go home!
TIA.
I might just do that. I just bought some bulbs for my headlights and fog lights that are supposed to illuminate the road better, but I'm not impressed with them. So I'm thinking of getting a Vision HID conversion kit, that's the only way to get the true HID look.
I like the PIAA 6084, that appears to be an HID kit at around $1k. And the Vision HID kits are around $260.
Yes the FOG lights do suck for DRIVING, they work great in the fog though. I planned on replacing mine with driving lights that I liked, then figure out a way to mount them to the factory mounts, using the factory wires. If I do it soon, Ill write up a how to. Should be easy though, a little drilling here, a little there.
Good luck
Aaron
@davegee
I'm wondering the same thing for a '03 Denali. Would that 1500 series would as a replacement for those too?
Thanks!
Just finished installing a set of PIAA 540's in the OEM locations on my '05 Sierra. They fit perfectly in the 5" round bumper openings, not sure if the Denali cutouts are the same as the Sierra.
PIAA 540 Series
