Bridgestone Dueller OEM tires
Just curious, how many miles can I expect from a set of stock Bridgestone dueller A/T on my Z71?
Would you recommend slightly higher than recommended tire pressure for maximum longevity?
I usually run these at 38 psi cold (vs recommended 35 psi).
I've got about 42K on mine so far running the same pressure. I rotate every 10K and there is still 8/32nds left.
i got 31 out of mine and had them rotated every 3000-5000. my friend got 33 out of his and rotated them every 6000
I have 90000 kms on my 04 and I still have a little less than half the tread left.
I run mine at 36 pounds and rotate them every 15000 kms.
Just curious, any of you experienced excessive feathering of the front tire outer edges with these tires? I had that problem and since realigning the truck and rotating the tires, it is much better now.
yep. along with chunks of the tread coming off of them
Are you talking about the OEM Generals or Bridgestones? I hope it is not Bridgestones.
The Bridgestone Duellers on my truck didn't make it out of the dealers lot. Insisted they replace them with Michelin LTX-MS, all 5 of them before I would buy the truck.
i was talking about the bridgestones. i tried many times to get them replaced but just had to finally do it myself
yep, ive heard a lot of the trucks came out of the factory not aligned right!
Got 10,300 out of my factory Bridgestones, they had enough tread to make it through another summer but I was nto going to try to make it through winter with them. Rotated every 3000 miles and drove the truck like a grandma and they still didnt last. During the last few hunderd miles, I noticed they were very bad in the rain. I would spin out from stop signs and the ABS kicked in when braking. Glad I replaced them with Michelin LTX M/S.
Only 24,000 miles on my Duellers but i never rotated them either. I installed a set of Firestone Destination A/T's which I really like and had great reviews. 7,000 miles on them now and wearing great.
Bought my truck used with 32K miles on the clock. Tires looked decent but after the first snow/rain I took them off immediately! Love the Michelin Cross-Terrain SUV's. Night and day difference.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
