DTC B1025/1035/1045/1055
Shu
Does anyone know what these Diagnostic Trouble codes are:
B1025
B1035
B1045
B1055
DTC B1025, B1035, B1045, or B1055
Circuit Description
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers. The radio tests the speaker output circuits for a short to voltage or ground.
DTC Descriptors
This diagnostic procedure supports the following DTCs:
DTC B1025 Audio Output 1 (Left Front) Circuit
DTC B1035 Audio Output 2 (Right Front) Circuit
DTC B1045 Audio Output 3 (Left Rear) Circuit
DTC B1055 Audio Output 4 (Right Rear) Circuit
Conditions for Running the DTC
The test is performed when the radio switches from OFF to ON. The radio will continue to test for the fault once every 0.5 seconds.
Conditions for Setting the DTC
The radio sets a current status for this DTC when a short to ground or voltage is detected on any of the speaker channels for 1.5 seconds.
Action Taken When the DTC Sets
No sound is present from one or more of the speakers.
Conditions for Clearing the DTC
The condition is no longer present for 5 seconds.
