NAV DISC VER 5.0 (Part#15906573)
I have read a lot about people having "disc error" with their version 4.1, I just ordered the newest version, (Ver5.0) and am hoping this cures all bugs in ver 4.1. Has anybody ordered the new disc yet with good success using it? Thanks
I've got 5.0 and it's been working fine for the few months I've had it. This is my first disc.
    Fishboat
    Fishboat
  • Who's Online   7 Members, 0 Anonymous, 491 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
