Drive shaft removal for slipyolk Greasing
Kornstar56
Hello,
I recently bought a 2000 Silverado regular cab and am having problems with the driveline clunking right before coming to a stop. from reading the forums I've concluded that I need to grease the slip yolk. My problem is after I undo the 4 screws at the rear differential I cant get the drive shaft to slide at all. Is there a special way to drop it or am I missing Something?
Thanks in advanced :confused:
You're missing something. It should come right out of there. It might take a screwdriver for some leverage to get it started, but otherwise it's pretty straightforward.
This is about the right way to do it. Best advice is to have a screwdriver or a prybar handy. Unless you have a 2 piece driveshaft, in which case you need to unbolt the carrier bearing too.
Thanks alot for the replies, I sort of figured you had to pry on it but I wanted to make sure so I didnt break anything.
EDIT: I just finished up and the prying worked great. Thanks again for the advice. :confused:
