Question about 88-98 Seats
M J
Did :confused: make a BENCH seat for REGULAR cab that has the middle console that folds up and down to either make the 3rd middle seat or to store stuff in? kinda like a 60/40 but it would be one piece.....
Thanks
yes...the seat in my 97 is like that. The bottom is a bench and the backs are 40/20/40. The middle folds down with the storage compartment
if you want i actually have a pic of what it looks like
yeah if u want, attach the pic here, so others can see what im talking about, which leads to my next point, is anyone parting a truck or selling one of these?
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 193 Guests (See full list)
