95" C1500 - 350 TBI
valeboykid
okay guys, Im loving this forum already, cause unlike the others, we get answers here...
I have a 1995 C1500 350 - 5.7L in my burban. My mods so far are hypertech G3 PCM chip (recomends premium), K&N air filter, MSD ignition 6al and MSD GM blaster coil (will install coil this week)
Does anyone know about the hypertech chip? it came with my vehicle, but I would like to know how well of a chip it is. It does recomend premium. I normally use regular, however I put premium in 2 nights ago, and it seemed to burn a lot better and slower, and the truck diffently had some pep to its step!
the msd 6al is just amazing for this truck! major throttle response diffrent. also alot quicker.
truck has acdelco rapid fire spark plugs, bosch sprial wound wire, distribution cap and rotor. .... all this was part of my recent tune up.
However I would love to take the truck to track to get some numbers, and figure out what I need to do to make it faster.
can someone give my alot more information on my engine??? and what can i do to notice a difference.. thanks guys
Sounds like you pushed her as far you can without some serious mods like a new cam, springs etc.
A new cam with a tune for it would net you some more high rpm horsepower. The old 350 craps out around 4500 or so.
I think I did :gmc:
I was actually thinking "cam" when I started this thread, but I dont have much knowledge about cams... How hard is it to install or is it a expensive job? Im pretty satisfied right now, but I would like to get the most bang for the buck!!
:cool:
:cool:
a better cam will be enuff for me... lol
I dont want to do too many more mods like TC converter etc...
I belive a cam shaft and maybe some better valves or springs..
What kinda of gain will I get with a better cam and stock heads??
Is there someone who can recomend me a cam of a website or something? I just wana order it, and get it put in. Ive noticed some offer better gas mileage also, will does rob me of my power, or give the same as stock power? or maybe best of both worlds.
I also notived a street cam for performance, I need something good. But I atleast want the same gas mileage or better!
Recomendations??
With those mods, pretty good improvement in gas mileage and power. Feel most of the power in the seat and not at the track.
I would look at jegs, edelbrock, summit, or a Z06 cam for all your needs.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
