oil light reset
r.glover
can anyone tell me how to reset the change engine oil light
I'm assuming you got the light that stated it was time to change your oil? If yes-Turn you ignition key to run (do not start) and immediately pump the gas pedal 3X. Turn off key. You should now be reset.
Thanks from me too,light came on today,changed oil never knew how to reset! :confused:
  • 2 months later...
  • 10 months later...
Don't immediately turn the key off. I have a 2000 and I have to wait after pumping the gas about 10 seconds then the light will blink a few times then go off. Now you can turn the key off. At least that works for mine.
