Vette Dealer Employee crashes Car
chesney09
ugh, its one of those deals where the original story was replaced with a results commentary.
thanks to the internet, i read a story like that every week.
i got a quick one:
one of our stores is next to a Goodwrench service shop and the back parking lot shares the same parking lot as the back of our store. The salesman working that day drops the car off next door for an oil change, they do the oil change and in the back parking lot, the tech backing the car out does a burnout right infront of the owner/salesman while hes smoking a cigerette.
lit with rage, the owner/salesman walks around to the front of the store to where the tech is parking the car. the owner says, "that was a nice burnout" the tech not missing a beat says: (with a smile on his face) "yea, it was fun."
The owner in one punch knocked him out cold, laying there in the parking lot.
Long story short, free tires all around for the owner and the tech got fired (from what i heard)
Not that I'm condoning beating on a customer's car. Assuming a customer could knock me out, I guess it would be a good thing that his car got new tires. That way he gets more money for it when he has to sell it to come up with the cash I'll sue him for.
There's gotta be an ending like that to that story. I'm sure the dealer terminated the tech. But the tech must've went after the customer after that, either legally or uh, not legally.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
