Chip for 6.0
Has any one put a "chip" in the PU that have the 6.0 eng. Local dealer said it would give about 30 HP. He didn't have the torque #'s or the mpg change. Need a little more git up an go. I have the GMC Denali with the 6.0.
look into the SuperChips Flashpaq
i put one on my 99' chevy and it made a big difference
While it's a slightly different version of the 6.0, I had mine tuned, and I can say that 30 hp is probably a good ballpark. Shifts are a TON better and more intuitive as well.
Run a couple of searches, there are a wide variety of people who do custom tunes for your truck. Prices ranging from $125-$650...You'll find a wealth of information on the subject here, and see that pretty much everybody says to go with a custom tune instead of a handheld tuner (Hypertech, etc).
can you guys give me names or web sights to look at custom tunes or am I beter off getting a hand held so when it goes to the dealer I can change it to stock
HPtuners.com
LS1 edit
I wouldnt even bother with Edit. Look to EFILive or HPT. Edit was great dont get me wrong. But with the way the EFILive and HPT "black-box" is designed to for direct connection of a wideband. You get the ability to add the WBO2 PID into the scanner suite and log it. PLUS you can also use AutoVE!!!!!!!!!!!!
  • 1 month later...
HPtuners.com
LS1 edit
You might want to check out Diable Sport tuners. I've used one on my PSD Ford X for years with great results.
http://www.diablosport.com/index.php?modul...splay&pid=3
I like it because you can choose between three different HP/Torque tunes on create a custom one yourself.
The one I have comes with 45HP towing, 65HP performance and 125HP racing tune. I run with the performance tune which puts me at about 385HP and 650LBs torgue. It's like an 8000lb jack rabbit. I have a modified air intake but only a 3.5 inch exhaust. I don't want to heat up those tranny temperatures to much.
Nelson. Good service, explains what they are doing.
I talked with others who were either not familiar with some variants of the GM truck familiy or who were misinformed.
Got about 50 hp to the rears with just a tune on stock truck. That's G-tech values, not butt dyno numbers.
Mike
