Radio Antenna
Does anyone know if you can screw the radio antenna off of a 2500HD? Year is 2001. I have purchased a truck cover and if I could screw the antenna off it would make it much easier to install the cover. I looked at it and it didn't appear to screw off.
I went for a ride in a 2002 a week or so ago.  The truck was fresh off the transporter and hadn't been prepped yet.  The antena was stuck in the map pocket on the passenger door and threaded up through the arm-rest.
I don't think the trucks have changed from 01 to 02 so I would say the answer is yes!!!
Look towards the base of it.  It comes to a thick cylinder shape w/ two sides lopped off.  Just take your trusty crescent wrench and loosen it a bit and then just unscrew it w/ your hand.  Piece of cake.  Make sure when you reinstall it you tighten it up otherwise it'll wobble when your driving and bug the heck out of you.
In the glovebox of my 2002 HD was a plastic wrench that was for the purpose of removing the antenna.Not exactly Snap-On material but thoughtfull of GM anyhow.
I had to take mine off and saw about 2" off of it because it kept hitting on the bottom edge of my garage door when I would pull in and out. That was way too annoying! :D
I think I got one of them also!  :D
Hey CMNTMXR81,pretty spiffy wrench,Huh?
Checked your pix out.Mine is same color with crewcab.Did you have to screw around with the 285's getting them to fit?The stockers look pretty puny.Had somebody tell me if you go to bigger tire with Allison you could get grief on warranty with tranny.Did you recalibrate speedo?
Hehee, actually I was staring at it for the longest time wondering what the heck it was for until I realized, DOH!!!  Antenna.  :)
No problem fitting them as I had already turned up the torsion bars, no trans problems and no recalibration.  My speedo/odo is about 7% slow.
People have asked about possible trans problems with the bigger tires and I don't buy it.  This transmission is capable of handling 16,000+lbs with either the 8.1 or Duramx twisting through it, a tire that's 4 sizes bigger isn't going to hurt it in any way, shape, or form.  If something happens internally to the trans, then it's something that was wrong long before putting bigger tires on.
As to warranty issues, this is a grey area.  See a thread I replied to about warranty issues not to long ago in this section.  Essentially it's dependant on the dealer.  Some couldn't care less, some see a cat-back system and are on the phone to GM to void your entire warranty.
At our dealership, they could've cared less, we were all for performance mods.  However the Chevy dealer down the road was run by a Nazi service manager who didn't tolerate anything.
Here ya go,
http://www.gm-trucks.com/cgi-bin....;t=7814
If that doesn't work, the thread is titled "Tires voiding warranty" here in this section.   :D
Thanks for the info.
Its' in the high 50's right now in northern NY and I think I'll go out and attempt to install my Westin bars,tonno cover and see if the pressure blaster still works.
Bring on Spring,screw Winter. :)
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
