Poor Ford
Guest chevydeerhunter
An article I read said that they lost an average of $24,000 every minute of 2006. That's insane.
I like how companies loose this much money, and when the CEO's step down they still get a $100 million severance package...now thats insane.
Note to self...Become CEO of major compan... bankrupt it....step down, and still come out filthy rich.
