4.8 to 5.3 engine swap
Not worth the money, 4.8's aren't much weaker, only down 20 hp & 33 ftlbs, a 87/89 tune makes that up. Unless you get the 5.3 for free or really cheap, Id save your money. But if you really want a 5.3, it bolts to the 4.8 tranny, motor mounts Im not sure about, but thats an easy fix, also have to get computer programed for a 5.3.
Hell, if your gonna spend the money. Just find a 6.0!! Same type of swap really. Just gotta swap the flexplate from the 4.8 to the 6.0 and your good to go.
:shakehead:
and get a good tune for it......
:banghead:
  • 3 months later...
4.8 and 5.3 are the same block, same bore, same everything except the crank. if you are to do the swap there are no pcm reprograms needed.
i swapped my 5.3 for a 6.0.. I wish i would have done it 4 years ago... my truck runs SOOOO much better.. BTW... if you can turn a wrench it is super simple..
how much is it for a 87/89 tune?
$158.00 wait4me with the pcm included.
  • 1 month later...
Your almost totally correct....the pistons differ between the 2. The 5.3 has dished pistons, 4.8 does not.
Jack
Why bother its a 10 hp difference. I recommend exhaust or an air intake!
go to a 6.0 man...
I like my 4.8, If I was going to swap and spend that kinda money I would spend the few bucks extra and get the 6.0
However It depends on what you are wanting out of the truck.
If you have blown your 4.8 and theres a 5.3 readily available and you can get on the road again in under a week, I'd say go for it. But if your just wanting to do the swap to increase power and potential wait for a good solid 6.0 to come available
Just my 0.02
