S10 blazer Engine dies after warming
plugginaway
1989 S10Blazer 4.3L 4X4 - engine starts easily runs smoothly until warm and then just shuts off as if key were turned off. Can be started giving full throttle and pumping - but will not idle - have replaced fuel filter - fuel pump (it was bad) & tune up including plugs, wires, rotor, rotor cap and coil
IT'S HARD TO SAY WHAT IT IS. THERE ARE MANY POSSIBILITIES. WITH IT CUTTING OUT WHEN WARM I WOULD LOOK AT THESE SENSORS. COOLENT TEMP SENSOR, IDLE AIR VALVE, IGNITION MODULE, AND OIL PRESSURE SENDER.
Make sure your MAP sensor holds a vacuum. Also check that the vacuum line between TBI and MAP can also hold a vacuum.
//90GMCZ71
THE MAP SENSOR WOULD NOT CAUSE THE PROBLEM HE IS HAVING.
  • 5 months later...
hey newb here
i own a 1993 gmc jimmy having similar problems
runs fine when cold then warms up and starts to heistate buck/bogg out and then quits and un-able to restart until cold again
i however was able to at first when symptoms began to start up giving throttle and kinda milking the gas a lil then catchin it and it would run fine after but symptoms got worse now no longer able to do so..
changed fuel filter getting 60 psi at fuel rail and all sensors fine no codes hooked up the snap on scanner to it everything seems to be runnning with good voltage etc... looking for pointers and leads on to what may be the problem
you may message me on here or feel free to message me on email
[email protected]
thank you
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
