Heeellp! No start Silvy...
TEE
I have a 94 Silvy that's driving me nuts. When it's cold out and sat for awhile...it doesn't want to start. It will crank and crank but, no fuel is coming
out of the injectors. Everything has been replaced including fuel pump, lines, IAC, coil and temp sensor.
I'm tired of throwing $ at it.
Any ideas?
Thanks,
TEE
Any ideas?
Thanks,
TEE
Are you getting any spark?
Any ideas?
Thanks,
TEE
Yes...good spark but, no fuel. Now what's really weird is once it's started it seems to run fine. The last time I finally got it start..I poured some gas each side of the TBI and it finally started.
A lil' more info...if I depress the gas pedal slightly when it doesn't want to start...it starts.
check your idle air. you may not be getting enough air into the motor
Funny you mention that, when I took it to my buddy's shop this morning it threw a IAC code when he hooked it to his hand held scanner.
I'll let you know what happens....thanx
UPDATE
It was the four pin connecter to the IAC...one of the prongs was mashed over.
Runs like a champ now.
Thanx for the info :shakehead:
