Heater / AC Control Assy Swap
rufuscaffee27
Hello,
I own a 2005 Chevy Silverado extended cab truck with the manual dual zone climate control option. I purchased a heater / air conditioning control assy removed from a 2003 Chevy Silverado. I pulled off the dash panel and removed the heater / air conditioning control assy from my 2005 Chevy and found out that the electrical connectors for the two panels are different. The electrical connector that controls the digital display plugs directly into the 2003 heater / air conditioning control assy, but the other connector (blower control, I guess?) does not. Does anyone know what parts I will need to get this control panel to operate properly? Thank you for your time.
  • 2 months later...
Hello,
I know this isnt the answer but are you swapping from the manual sliders to the auto climate? Because if you are, I also would like to know if they can be swapped if they are going into the exact truck
Hello,
Do a search on this swap either on this site or SilveradoSS web site but I am 99.9% sure that it can not be done. There is alot more to this than you would think.
