4x4 switch control failure
Flash2004
My 2001 Sierra 2500HD SL/E has button control of the 4wd operations - 2hi/4hi/4lo - and most of the time there are no lights up on it. Normally when I first start it the light showing which mode is selected will be showing, I get a "check 4wd" message as I travel and the light will go out or come on and off intermittently. At these times I can usually not change drive modes except if I push and hold the button for a few minutes - which is better than walking if you need 4wd.
I saw once, on a forum somewhere, that this was a common fault with an easy fix. Anyone know what the fix is? Parts are very difficult for me to get so way down here so if possible, I need a repair process. Thanks, Gordon
If the problem is the switch, I have heard that reheating the solder joints on the back of the switch will usually work. Apparently cold solder joints were an issue with them.
  • 1 month later...
Thanks for that James, I've been away a while and so did not reply sooner. It sounds like a "doable" idea, I knew it was a quick and easy fix and that sounds right. I'll give it a try but have bigger problems to solve with the truck right now. cheers, Gordon
