Hunter Stainless Brush Bar/Gaurd
vinniej
I have a Hunter Stainless steel brush bar/guard. there is nothing wrong with it, my truck just won't fit in my garage with it on. due to the size of it we will have to do this pick up only (no shipping). I'm looking to clear some space so the first $100 takes it.
assuming its off the '06?
yes, and if I recall will fit any silverado (1500 all the way to the 3500 even the HD trucks) with the 03 and newer front end.
  • 1 month later...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
