K&N CAI question
Ok,
Last weekend I put in the K&N CAI [i don't rember the series, but it was the plastic one...]
My question is, the kit came with new tubing and a fiting for the crankcase vent. As a good boy I installed the fitting and ran the tube.
The stock tube was not mentioned as to what should be done.
I plugged it off, and continued on with the project.
In the event moisture would condense in there, and possibly make it into the throttlebody I'm guessing much bad...
Any problem re-installing the old tube, and plugging the 1/4 NPT connection on the K&N?
Or should I look into a full removal of the stock tube? It is behind the throttle body "butterfly valve" wheras the K&N location is mid intake tube.
Thanks
H
