KYB or Bilstien
'05 1/2 ton ext cab 4wd Sierra WT. Planning spring time project for my rig. Thinking Ford torsion keys to lift the nose a couple inches and give a bit of clearance for 285/70/17 Goodyear Wrangler Silent armor tires. Figured I should also install longer shocks to go with the t-bar lift. KYB has the Monomax for trucks with 1"-4" of lift, I'm assuming Bilstien must offer a slightly longer shock as well. Opinions wanted.
I like the KYB stuff. I have them on my rig and like the ride. The Bill's are expensive amd I have not found any major advantage.
After running Bilsteins (I've run 5150 on a DD and have 9300 Coilovers waiting mounting on my Trail-rig) I would never run any other shock. When it comes time for replacements in my '03 Silverado I'll be giving a Bilstein dealer a call.
Hello:
My 05 1/2 ton Ex-Cab 4x4 felt like it wanted to float every time I went over a dip at any speed. After reading reports on this forum, I finally decided to go with the Bilstein's. I'm happy I did. The truck now keeps ALL the wheels on the street!
Richard
Haven't run the KYB's but I'm on my second set of Bilstien HD's on my Tahoe. The improvement in handling was significant. Much better cornering and a slightly firmer ride. They seem to help towing also. As Meatco1 said, it feels like all four wheels are firmly planted on the road.
I've never run any of bil's higher-end assemblies like RCman, just the standard HD's and I probably wouldn't buy them again. I've gotten a much better ride out of my RS9000X's, and will be replaceing these with the slightly longer KYB MonoMax in the near future. Good luck on your decision
I do not think you can go wrong with either. I am partial to the KYB because they are our (CARQUEST) Supplier of ride control. The quality and construction is second to none and the MONO MAX is a really great shock for heavy use or 4 WD applications.
Thanks for the replies. Sounds like either brand will be an improvement over the stockers. Now how about opinions on using the longer shocks with only a mild t-bar lift? Nessesary?
No need if you don't go crazy cranking them. 1.5 inch or even 2 inch should not be an issue.
plus, an advantage over the kyb is that bilstein is german and kyb is japanese. i wouldnt put rims off of a toyota onto my silverado! plus ive heard good things about bilstein. i have kybs in my summer car and they suck.
