MPG on the 6000 engine?
Thinking about getting a 2003 1500HD 4X4 this fall.  Just wondering what kind of gas milage to expect from the 6000 with auto trans.  Figured you guys with the 2500HD could give an idea.
Just out of curiosity, why are you buying the 1500 HD instead of the 2500 HD?  The cost isn't that much more for the 2500.  Anyway, we have the 2500 HD w/6.0 eng w/ 4.10 gears.  We get anywhere from 9 mpg (towing our fifth wheel) to 13 mpg on hwy.  We did get 14 mpg on one trip though.
An update!  Just got back from trip to Irvine, CA and got 15.5 mpg on this trip, traveling about 230 mi each way and at 65-73 mph, depending on traffic.  I think that K & N air filter has helped some.
Hi all,
I just got a 02 k2500 (non Hd) 6.0 w3.73 rear and am getting 10.0 mpg. I just did my 1st oil change and switched to 5/30 mobil 1 but dont hope for much more. I have a leer cap, 265 bfgs and a big block series muffler, none of which has made a dent in the mpg, just 230 miles on 23 gallons of gas!
Am also a new guy here, nice board!
Dougsster
On my second tank I got 12.5 mpg. city driving to and from work mainly.  I am a bit lead footed at times though. the 6.0L has sort of a "growl" to it that's very difficult to ignore when you press the accellerator.  Quite tempting to do this alot!
One things for sure, it blows the doors off Ford's 4.8!
A friend at work consistently gets 15-16 mpg's with his 1500HD and 3.73 gears.
I just got one of my best tanks out of my 2500HD with 4.10 gears at 14.5 mpg's.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
