new guy on the block
FordMan77
Since I'm new, thought I'd stop in and say hello. While I don't currently own a Chevy or GMC truck this looks like the place to be to learn a thing or two. Before anyone bashes me for my screename, I will say that I have a love of all things automotive, not just Ford products (you can gag now, lol... it's ok). I've been working w/ my buddy to help out his 01 Silverado and figured this is a good place to start. I look forward to talking with you all in the forums. And no worries as I know how to use the search feature of forums so as to avoid asking redundant questions, lol... Well, at least I'll try :thumbs:
Jay
Welcome! :thumbs:
Don't worry,We won't pick on you to bad for havin' a F@#d :sigh:
Thanks for the welcome. And as far as me owning some Fords, does it count if I have a 95 Formula Firebird half apart in the garage, lol... At least that is partially GM last I checked, at least what's left of it :rolleyes:
